Results 1 to 10 of 25
Thread: Whats the stud pattern and offset of an Audi A4?
    Default Whats the stud pattern and offset of an Audi A4?
    i know its 5x112 but is the offset 35 like the b5?
    for which? B6?
    **** sorry B7
    Quote Originally Posted by XXX-1.8T View Post
    **** sorry B7
    Depending on the size and width of the rims.
    it could range from ET 45 to ET 35
    Stock wheel offset is 42, but ive found 38 looks best
    2008 Audi S5 - 20" Forged DPE 3 Piece Wheels, Nitto Invo 285/25 Tyres, H&R Suspension
    2007 VW R32
    2006 Audi A4 2.0T Quattro 6MT Sline - SOLD
    I think all factory fit B6/B7 wheels had offsets in the vicinity of 39-45mm.
    so would 18x8.5 offset 35 fit a B7?
    OEM S-line Wheels
    Diameter: 18"
    Width: 8"
    Offset: 43mm
    Made by Ronal
    OEM 17" Split Spoke 5 Spoke Wheels
    Diameter: 17"
    Width: 7.5"
    Offset: 45mm
    Stock Rotor size
    • Front - 12.6"/320x30 mm - Ventilated disc / ContiTeves FNRG-6
    • Rear - 11.3"/ 288x12 mm - Solid disc / TRW CII-41
    Rim Size - Offset
    7.5in - 25mm
    8.0in - 32mm
    8.5in - 38mm
    9.0in - 44mm
    *NOTE* - I am not a wheel professional and can’t guarantee these wheel offsets will fit. The offsets above place 70mm of rim from the mounting surface to the front edge (which is close to the fender). From installs listed on the forums and what manufactures sell; the offsets can be +/- 3mm from listed.
    **NOTE** - The B7 A4 has very large stock front calipers (B5 S4 size) so becareful when purchasing rims. Due to their design (including spoke design) they may not fit over the calipers.
    2007 VW R32
    your a legend Mr P
    what about the B6? does it change if its quattro?
