Thread: Changing S-Tronic Paddles
    Mar 2009
    The Hills, Sydney
    4,029
    Thanked: 27
    Default Changing S-Tronic Paddles
    Changing paddles while initially seeming hard is quite easy.
    Here's how it's done
    Use a flat bladed screwdriver to prise out plastic tab on either sidewheel. At this stage the ignition will need to be on to turn wheel.
    Use a T20 Torx driver to undo bolt under each tab. WHEN FINISHED TURN OFF IGNITION
    MAKE SURE IGNITION IS OFF
    Remove centre boss (containing airbag) from wheel- pulls straight off. No need to unplug.
    Then carefully prise one piece aluminium trim off the three spokes and circumference of centre of wheel.
    T20 Torx bolt that secures centre boss can be seen here.
    Undo black T15 Torx screw.
    Locate red/grey/yellow cable and unclip.
    Poke cable through wheel spoke and paddle comes straight off.
    09 TTS DSG Ice Silver - APR: Stg II+ remap,Fuel pump,Big Bore Dump Pipe/Sport Cat. Forge:Catch Can,DV. GruppeM:CAI. OSIR: Carbon Front and Rear Spoiler, Grille,Rear Valance,Engine Bay Covers, Full OSIR interior.TID: Steering wheel (CF),Ultra paddles, Full TID interior,Bonnet (FG). DEFI:In OSIR O Rings;Boost,Exhaust Temp,Oil Temp. CUSTOM: CF Mirrors & pedestals, CF Engine Cover
    Jan 2022
    37
    Thanked: 1
    I can change all led color as well..
