Results 1 to 9 of 9
Thread: i think a coil pack just died! (b5s4)
    May 2012
    Brisbane, north side
    118
    Thanked: 6
    Default i think a coil pack just died! (b5s4)
    2001 B5 S4, drove to work fine, not happy on way home, whole car osscilates at idle subtly, but apply a gentle foot and the car sounds awful, judders wont pull, sounds like misfire. My guess is coil pack, I dont have any diagnostic stuff, week before xmas, all looking bad.... rang audi brisbane, $180 each and ex sydney. so....
    obv cheaper ex overseas but is this the going price in australia?! is there an after market part? i am guessing its not a plug/lead, wouldnt expect such a sudden failure.
    any help/suggestions finely appreciated!
    thanks
    ian
    gone 2001 nogaro blue S4 avant, UR quattro,
    NOW b7 RS4 sedan
    Quote Originally Posted by ian View Post
    thanks
    ian
    http://www.ozaudi.com/forums/showthread.php?t=39549
    try get in contact with dcc236,
    2000 Audi
    S4 K04d
    2008 Yamaha
    R1
    Previous
    1996 Audi A4 1.8T Quattro
    1996 Nissan Skyline GTST *highly modified
  3. The Following User Says Thank You to 18TQ For This Useful Post:
    ian (December 14th, 2012)
    May 2012
    118
    Thanked: 6
    thanks, great suggestion, just pmd him
    NOW b7 RS4 sedan
    Apr 2012
    Brisbane, Qld
    1,027
    Thanked: 34
    Default Coil Packs
    Ian
    I just got 6 from the US
    happy to loan you one or two subject to replacement
    might let you buy some form a cheaper OS site
    call me if David cant help you
    Graze
    2017 Aston Martin V12 Vantage
    2011, 8T RS5, Suzuka Grey
    1965 Triumph TR4, Red
    Sold
    2007 Aston Martin V8 Vantage
    2001 B5 RS4, Black Pearl Metallic, B7 RS4 wheels with 275/30/19's, Neuspeed rear ARB, 18Z cayenne six pots, JHM short shifter
    1975 Triumph TR6, French Blue,
    2010 Mini Cooper S
    Previous 2007 B7 RS4, 2007 B7 S4, 2005 B6 Avant Quattro, 2001 B5 Avant Quattro, 2001 S3
    Oct 2012
    Pakenham, VIC
    20
    I went through the same thing and only just fixed it today at home. Fault finding to the max and swapped around coil packs when I thought I found a dead one. The dead one remained dead on all cyclinders. Bought 4 new coil packs and back running smooth again. The car was reacting like a cylinder had dropped, exhaust sucking, fluttering under acceleration etc.
    Sep 2005
    Brisbane
    3,329
    Thanked: 55
    My recent issue turned out to be a faulty ICM. Ask the dealer for a price on one of the two ICM's we have in the car, I was quoted $575 each.
    Could be any number of things. Here is a short list:
    - icm or wiring
    - coil packs or wiring
    - spark plug
    - boost leak
    - cam shaft lobe wear (unlikely but possible)
    VCDS scan is a good starting point.
    Given the age of these things, refreshing the ignition components is a good idea.
  8. The Following User Says Thank You to dcc236 For This Useful Post:
    ian (December 15th, 2012)
    May 2012
    118
    Thanked: 6
    my thanks to David who has got me moving again. turned out to be ICM, but now researching the complete change kits to eliminate them. good timing with xmas, the wallets already bleeding!!
    NOW b7 RS4 sedan
  10. #8
    May 2012
    118
    Thanked: 6
    just replaced all coil packs, both ICMs in the s4 (plus plugs). considered various options incl the integrated kits available. However, i went cheap!
    http://cgi.ebay.com.au/ws/eBayISAPI....m=120774007937
    got this tune up kit, landed within a week from USA off ebay, all after market bits, all fit perfectly, car runs as it should. I dont know what teh quality difference is between the expensive and cheap options but time will tell! If it all starts to fail I will have to go down the double or more price root. total cost $269AU.
    Now i have to return my loan parts to their owner (thanks again!)
    ian
    NOW b7 RS4 sedan
  11. #9
    Jan 2010
    Fitzroy
    1,327
    Thanked: 31
    +1 for having this happening to me in my old S4
    Now - 2016 Golf R - Thinks he's an S3
    Then - 02 Golf Gti, 99 S4 Stage 1, 00 S4 Stage 3, 01 RS4 Stage 2, 77 Fox, 75 Fox, 87 200 Tq Stage 1, 82 coupe GT, 87 90 Quattro
