Page 44 of 44 FirstFirst ... 34424344
Results 431 to 440 of 440
Thread: PROJECT: (R)S2 = More Power
  1. #431
    Jul 2005
    2,775
    Thanked: 31
    So is that close to 900hp at the crack?
    How straight does it pull when all the horses come in when the turbo spools up?
    I miss that feeling!!!
    Awesome job mate..
    Sent from my SM-G950F using Tapatalk
    Surprisingly straight and true... providing the tires hold traction.
    It is a great feeling
    - Audi S2 1993 - Kingfisher Blue - GTX3584rs + E98 = 760 whp
    - Porsche Macan S 2017 - Sapphire Blue
    Past:
    - Audi SQ5 2013 - Panther Black
    - Audi S4 2002 - Nogaro Blue - Stage 3+ 249 Kw atw
    - Audi S3 2001 - Silver -
    169 Kw atw
    *Understeer is when you hit the wall with the front of your car and over steer is when you hit the wall with the rear of your car.
    *Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
  2. #432
    Quote Originally Posted by Tas_Audi View Post
    A 2nd battery doesn't fix the problem it just delays the inevitable, if the alternator cant keep up with demand. 1 or 2 batteries makes no difference.
    Respectively disagree in these circumstances. Runs at 98% with the existing alternator so it seems. 100% apparently needs extra amps to keep the voltage up. How often / for how long does any engine run at 100%. The top 2% of the power band, drag strip or standing 1000 mtrs is about the only time you'd need that 2%, between 8 and 20 seconds perhaps. For those you could run it on battery alone.
  3. #433
    Apr 2008
    Sheffield,Tasmania
    282
    Thanked: 13
    Yes agree if you are only doing short duration runs. If that is the case take the alternator out all together and gain some extra kw. Extended duration runs, the alternator needs to be sized adequately.
    Current - 2007 B7 RS4 Avant, APR Stage 3, Milltek with Hi Flo Cats, GruppeM intake, Sachs Clutch, Factory Ceramics, JHM Shifter, RS6 FBSTW, AMI & Hi Res RSNE
    Current - 2012 B8 A4, 2.0T Quattro Avant SLine
    Current - 2001 B5 S4 Imola Yellow Avant
    Current - 1989 B3 90 Quattro - 7A NA Engine, (Long Term Restoration Project)
    Current - 1984 WR Ur Quattro
  4. #434
    What a beast mate. Congratulations.
  5. The Following User Says Thank You to jsol For This Useful Post:
    momento1 (December 9th, 2019)
  6. #435
    Just seen a post where they were using a super capacitor to boost available power. This was for some music system where the alternator peak output was suspect and maybe the same principal could apply if it is the alternator output.
  7. #436
    4,979
    Thanked: 588
    large super capacitor... me like..
  8. #437
    Starting to sound a bit like Star Wars.
  9. #438
    Sep 2006
    Fairfield Sydney
    1,330
    Thanked: 8
    Or a bit like back to the future...
    Sent from my SM-G965F using Tapatalk
    Now > 99 A4 1.8TQ (silver)
    Handling
    KW V3's | Hotchkies Front and Rear Sways | 320mm Brembo BBK |
    Power
    Garrett GT3076r 52 Trim 0.63 A/R| Haltech PS1000 (custom harness PNP) | Piper Ultimate Road Cams | Scat Rods | JE Pistons | Supertech Valve Set | IE Springs Set | Full Race Ex Mani | Custom Enlarged Intake Mani | 1000cc Inj | Zietronix Flex Fuel Sensor | Treadstone TR18 FMIC
    R.I.P > 98 A4 1.8TQ (cactus green)
  10. #439
    I think youl find Marco has a 90 amp alternator rather than the Bosch 120 amp
    Sent from my SM-G955F using Tapatalk
  11. #440
    Jul 2005
    2,775
    Thanked: 31
    Default PROJECT: (R)S2 = More Power
    Sorry i never updated here.....
    turns out was actually just faulty old wiring on the injectors causing shorts. So we redid all the injector wiring.
    Car is running sweet, but i think its time to convert to DBW as the idle control valve is proving tedious to adjust perfectly considering the lumpy cams.
    And need to replace all lower bushes so i can fine adjust suspension and lower the ride height alight as well
    This will be
    a project for the new year as a bit is happening in my life at the moment.
    However i can finally say that the car is 100% complete externally in all her colour coded goodness... so that just leaves a complete make over of the interior, and of course the fin adjustments to the engine DBW and possibly a latest model ecu which will make it easier for complete finer adjustments to the tune
    Just need to readjust the driver and passenger doors to line up again after the respray as the mis-alignment is pissing me off at the moment...
    Past:
    169 Kw atw
  12. The Following User Says Thank You to momento1 For This Useful Post:
    Gbomer (October 17th, 2020)
