As there was on the Golf R.
Golf R had it by default.
Audi S3 without the folding mirror option can do the LHS mirror dip by enabling it with VCDS - uses the power mirror motor.
Those with the folding mirror option as we have, automatically get the LHS mirror dip function enabled.
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
mikejr (April 10th, 2016)
I still haven't seen the need to make any changes with VCDS. I did set up with a tuner in Brisbane to do some before I got the car but haven't found the need and the less things get touched the better IMO.
Anyone in Sydney keen to help me out with the following? I can come to you!
Set Oil Temperature on all DIS Menus
[17] Instruments
Go to Long Coding
Byte 10, Bit 1. Display Oil Temperature
Tick Box
'02 Ebony Black Audi S3 | MTM ECU | MTM Exhaust | 42DraftDesigns Downpipe | BMC CDA | APR R1 DV | Modshack Stage 3 | Red Forge Hose Kit | ECS Dogbone | Dieselgeek Short Shift | H&R Coilovers | ECS Adjustable Tie Arms | Haldex | Staggered 19" Axis Hiro... most mods sold : (
'16 Glacier White Audi RS3
You are a god amongst men.. It was killing me not having it
Me: MY16 Audi S3 Daytona Grey
Mrs : MY16 VW Polo GTI Pure White
There is a massive pdf file documenting all VCDS options (10MB - on Audi Sport dot Net)
I can email it to you if you want.
This is an extract - was posted here on this forum too I think.
Security Codes
[03] ABS Brakes is 20103
[09] Central Electronics is 31347
[10] Parking aid is 71679
[13] Auto distance regulation is 14117
[44] Steering Assist is 19249
[A5] Frt Sens. Drv. Assist is 20103
8V VCDS Mods | Page 7 | Audi-Sport.net
OTHER PROCEDURES:
Access MMI engineering menu
The engineering menu can be accessed with the following combination: Back button + Navigation button 1 (top left).
MMI Reset / Restart using monkey grip
The MMI system in the Audi A3 8V can be restarted by following: Menu button +
Confirmation button + Navigation key 3 (top right). The MMI then shuts down and restarts. Takes about 30 seconds
Mirror dip on Reverse
- [52] Door Electronics, Passenger > Long coding > Byte 04 > Set bits 02 and
03
[17] Instruments
Go to Long Coding
Enable Byte 10, Bit 1. Display Oil Temperature
ACC default distance setting in MMI
Adaptation: Option For Presetting of time gap Change 0 to 1
Save
Reboot MMI (Menu + Push Touch Knob + Top Right Corner Button)
Disable DRL's in Light Switch 'O' Position
Adaptation : (9) Tagfahrlicht-Tagfahrlicht nur in Schalterstellung AUTO Set Active
Disable DRL's when handbrake on
Adaptation : (5)-Daytime running lights- Tagfshrlicht-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten
Set Active
Autolock when leaving/away from the car
[05] Access/Start Authorization
Long Coding - 07 -> Long Coding Helper
Byte 2
Enable bit 4
As the current VCDS doesn't give you a check box for bit 4, you need to modify the binary string manually.
So the current binary string of 00001100 becomes 00011100 - which changes the value of the byte 2 from 0C to 1C
Enable TMC
[5F] Information Electr.
Adaption : Fee-Based Traffic Information (TMC) New value - 1024
After activating - TP needs to be activated in set-up menu for radio
Acoustic (Alarm Beep) on Lock/Unlock
Adaptation channels :
(1)-Acknowledgement Signals - Akustische Rueckmeldung entriegen (Un-lock acoustic feedback)
(2)-Acknowledgement Signals - Akustische Rueckmeldung verriegeln (Lock acoustic feedback)
Set each or one of them to Yes
Acoustic Lock Menu in MMI
Adaptation : Acknowledgement Signals -Menuesteuerung akustische Rueckmeldung
Set Yes
Adjust Switch Off Speed For Parking Plus
[10] Park/Steer Assist
Adaptation : Switch off speed for parking assist
Change to desired speed (default 10km/h)
Adjustment of the seat heater level lowering time (level 3 to 2)
[08] HVAC
Adaptation : Time until heated seat power withdrawel stage 3 to stage 2 Adjust value (default 10min)
(Value 0 = no automatic lowering)
Set number of indicator flashes
Adaptation : Channel (2) Select Turn signal control Komfortblinken Blinkzyklen Set 1-5 (default 3)
Set START / STOP
1. Module 19 (Can Gateway)
2. Adaption (10)
3. Go to channel: Start_stop_voltage_limit
4. Change value to 12.1V ( default is 7.6V)
DRL’s rear always on
Adaptation : ??
1. Select STG 09 (vehicle power)
2. STG access permissions -> Function 16
3. Enter access code 31347
4. STG adjustment -> Function 10
5. Channel (6) - Daytime Running Lights - daytime running lights additionally activated select still light
6. Put emphasis on active
Or 2nd method (DRL not on when light switch in 0 or non-auto position): For rear DRL:
STG 09 Cent Elect
Function 16 enter Security code 31347
Fuction 10 Adaption
Select Leuchte23SL HLC10 light function D23
Then select do it. This should turn on the rear right light.
Then select leuchte24SL HRA65 light function D24, then select do it. This should turn on the left rear light.
DRL’s brightness when indicator flashes
STG 09
Access code 31347
Adaptation
[18]-Leuchte2SL VLB10-Dimmwert GH 2
Default: 30%. Set to: 60%.
[18]-Leuchte3SL VRB21-Dimmwert GH 3
Disable seatbelt warning -
[17] Instruments -> Long Coding -> Byte 0 ->
CHANGE: Set bits 2-4 using combo box
Visual representation of the parking aid (Audi Parking System APS)
[10] Parking aid 2 -> Long coding -> Byte 2 ->
CHANGE: Set Bit 0 - visual representation parking sensors
SoundAktor
1. Select STG A9 (Körperschallaktuator)
2. STG adjustment -> Function 10
3. Select a channel volume of the actuator for seismic
4. Adjust value corresponding
Default value: 100%
In adjustment to value 0 the sound amplifier is completely disabled
Exhaust flaps all open
===================1 - Engine module Exhaust Flaps deactivate
Byte 9
Bit 2 - Exhaust Flaps installed check box default activated - deactivate it and save as usual.
Thanks Dusktildawn sorted my mirror dip, TCM and Oil on all menus.. damn that mirror dip was driving me nuts.. really good to have it back.
SilvRFoxx (April 10th, 2016)
Does anyone know if it is possible to permanently disable Audi Pre-Sense?
Also I have Adaptive Cruise Control and thoroughly hate it, can cars with ACC be coded to use normal cruise control?
