Thread: Auto electrician - Adelaide
    Adelaide, SA
    264
    Thanked: 3
    Default Auto electrician - Adelaide
    Anyone know a good auto electrician in the Adelaide area?
    Air bag light is on, passenger side fix worked, driver's side fix failed x3 and now steering wheel airbag fault indicated on VAGcom scan.
    TIA
    Black 11 Audi Q7 4.2 TDI S-line
    Black 03 Cayenne Turbo - CRUNCH
    Black 04 B6 S4 - SOLD
    Black 02 B5 S4, DNA stage ~3 - SOLD !!
    Depends where you are. I'm in the hills and Adelaide Hills Auto Electrical at Bridgewater have done some good work for me in the past. Know what they are talking about and don't charge an arm and a leg. Not sure if they are up to speed on the latest VAG products tho.
    Oct 2007
    1,997
    Thanked: 133
    Steering wheel airbag faults are often caused by a clock spring failure. The clock spring is an enclosed wire coil harness that allows for the steering wheel to go about its day job while giving you things like stereo adjustments, cruise control and gear shifting on the wheel - plus, of course, the airbag.
    If it's failed it will require replacement - not a difficult job.
    Marty
    Gone but not forgotten:
    ​1997 A4 Quattro V6 Manual "Hamilton's Club Sport"
  4. The Following User Says Thank You to 27litres For This Useful Post:
    dottorone (April 11th, 2016)
