Sorry it's for a 2005 audi tt 3.2l
Sent from my SPH-L720 using Tapatalk
Can anyone help tell me how to remove the front passenger side bearing? I have already removed the caliper, rotor, and inner break guard. Do I need to take off the control arm, or anything else? Thanks
If you can still put the car on the ground, I'd recommend doing that. Pop the wheel centre out first if it's still fitted as you'll need to access the centre bolt through the wheel with the cars weight on it.
If it's a hex head bolt it's probably 27mm. If it's an Allen key head it'll most likely be 17mm.
You'll need a breaker bar and mid extension to clear the wheel and probably some kind of extension bar for the breaker bar (or buy a big one!) - I use a length of galvanised water pipe to do mine!
You can try using a rattle gun - but I've never had success with one!
Marty
Gone but not forgotten:
1997 A4 Quattro V6 Manual "Hamilton's Club Sport"
Thanks we got it fixed and she is running smooth as ever :)
