Thread: Anyone got a spare 1.8T ECU I can borrow for an hour??
    Jan 2007
    Perth
    177
    Default Anyone got a spare 1.8T ECU I can borrow for an hour??
    Yes, I'm still here ... just!
    I need to confirm that my ECU (Engine) is the reason why I can't start the TT. Trouble is VCDS is not throwing up any DTC's ... but neither is it talking to the engine.
    2000 TTQ Roadster -
    |APR Stage III+ | APR FMIC | APR/Brembo GTs | Sachs Racing Clutch | Miltek resonated Cat back | Haldex Performance | 18" RS4s (rep) | APR R1 DV | Xenons | OSIR Orbit Ring
    Apr 2015
    155
    Thanked: 9
    if you've been trying to flash and uploaded an unchecksummed file or one not compatible and the ECu isn't reading anymore you should be able to connect again after you remove the battery terminals for about a minute or 5. reconnect them and try connect again with vcds
    should get you talking to the ECU :)
    "Let food be thy medicine and let medicine be thy food" - Hippocrates
    Jan 2007
    Perth
    177
    Thanks Ian,
    Done that. VCDS actually comes back with "Intermittent Connection" on one of the Blocks.
    2000 TTQ Roadster -
    May 2008
    883
    Thanked: 52
    Quote Originally Posted by Stats View Post
    I don't believe you will just be able to swap the ECU and start the car as per say because the loan ECU will have Immobiliser enabled on it.
    Get over to NefMoto - Index for more reading.
    Apr 2015
    155
    Thanked: 9
    which measuring block???
    Apr 2015
    155
    Thanked: 9
    just as long as the loan ECU has been IMMO off if will work.
    I have an ECU from 225 S3 but won't work cuz different model number.
    Quote Originally Posted by mike View Post
    May 2008
    883
    Thanked: 52
    Quote Originally Posted by Ian P Gonzaga View Post
    Correct, I was pointing it out to the OP that don't expect to just plug it in and it will work.
