Quote Originally Posted by Khoa View Post
Is that a Proven catch can? What's the correct way to set up a catch can with these engines?
It's a Provent 200 catch can. Setting one of these up is easy because of the inbuilt Pressure Regulating Valve. Just replace the factory PRV with the catch can, add a couple of lines to mount it remotely. Add a drain line with a tap at the end to drain the catch can when needed and you are done. The you can sit back and enjoy clean intake motoring by not having your intercoolers fill with oil overtime from the crankcase blowby.
