Results 1 to 10 of 10
Thread: Paint Brembo Calipers
    Default Paint Brembo Calipers
    Hi, anyone know of any good workshops in Sydney that paint brake calipers. Thanks
    Quote Originally Posted by War300 View Post
    Try Sam at CNC / Landsvale.
    Audi S3 8V sedan (MY15)
    - Misano Red w/Black Optics + Perf Pack + Pano Roof + US grille.
    - ABT ECU tune & DP | VWR CAI | TMD | HiFlo bend | Intake hose.
    - H&R Sports + spacers + RSB.
    - ECS Tuning 2 piece rotors + EBC Red Stuff pads (fr & rear)
    - 034 Motorsport - rear subframe mounts / dog bone insert mount.
    - Cobra resonated catback s/s exhaust.
    - Opticoat Pro treatment exterior & interior.
    - Coming Jan 18 Wagner FMIC + Spulen charge pipes + GFB DV+
    We also do them (Warringah Brake & Clutch Centre), full disassemble and bead blast, replace main seals at a minimum and powdercoated. Click image for larger version.
  5. The Following User Says Thank You to Viperzx For This Useful Post:
    Korny (January 5th, 2018)
    In melbourne we got a gang that powdercoat them. Ive had my cousin and a few mates rebuild there brembos and they have come out wicked. Also seen some work done on ferrari calipers to reasonably priced.
    Sent from my SM-G930F using Tapatalk
    2000 Audi
    S4 K04d
    2008 Yamaha
    R1
    Previous
    1996 Audi A4 1.8T Quattro
    1996 Nissan Skyline GTST *highly modified
    Quote Originally Posted by Viperzx View Post
    Sounds handy. What would it cost to get say the RS 8 piston brembos rebuilt and painted?
    I've had an old set sitting in my cupboard for the past seven years or so gathering dust.
    Thought I'd get them re-done in silver but have never gotten around to it.
    Quote Originally Posted by don View Post
    For those RS calipers: disassembly, blasting, powder-coating and reassembly including stickers the cost is $400, the problem might be the seals on those if only the main seals are required and dust boots are re-usable we're ok if not we or yourself need to get the caliper kits most likely from Italy. The pistons should be ok but we wouldn't be able to tell until we take it all apart unfortunately.
    Ok thanks, when I get a chance I'll check to see if the dust boots I have are ok. I did get a seal kit ages ago but not sure about the rest.
    So the $400 is for the set (pair) or per side? Plus parts of course.
    Correct $400 for the pair plus parts.
    Just thought I'd link in my results after having this done on my old 8 piston brembos. Turned out great:
    http://www.ozaudi.com/forums/showthr...909#post467909
