Thread: Replacement of the caliper face plate
    Default Replacement of the caliper face plate
    Has anyone performed the removal of the caliper face plate? I want to paint the black face plate tornado red to match the remainder of the caliper and cannot find any detail on how these are removed?
    I presume the caliper needs to be removed but thought Id ask before attempting it...
    Thanks!
    Audi S3 8V sedan (MY15)
    - Misano Red w/Black Optics + Perf Pack + Pano Roof + US grille
    - ABT ECU tune & DP | VWR CAI | TMD | HiFlo bend | Intake hose | GFB DV+
    - H&R Sports + spacers + RSB.
    - ECS Tuning 2 piece rotors + EBC Red Stuff pads (fr & rear)
    - 034 Motorsport - rear subframe mounts / dog bone insert
    - Cobra resonated catback s/s exhaust
    - Opticoat Pro treatment exterior & interior
    - Coming Jan 18 Wagner FMIC + Spulen charge pipes
    Quote Originally Posted by Korny View Post
    Thanks!
    Help! lol
    Looking at the parts picture you have a faceplate with two plain location studs and two friction inserts. I would guesstimate that the caliper locating holes house the friction retainers and then the face plate just presses in. On that basis the face plate should just pry off. Try a plastic trim tool and see what happens.
  4. The Following User Says Thank You to IchBautAuto For This Useful Post:
    Korny (January 15th, 2018)
    Do you reckon that you need to remove the pads to then reinstall?
    Frankly no idea but I wouldn't have thought so. From the pictures it just looks like a push fit.
  7. The Following User Says Thank You to IchBautAuto For This Useful Post:
    Korny (January 16th, 2018)
    Ok, just wondered how the placement of the retention clips would then occur. Cheers...
    In the examples of this type of retainer I have used, the clip is placed in the recess and usually has a protrusion that locks it in the hole, then the studs are just pushed into the location holes and retained by friction from the captive clips. I can only go on the photos that you have posted but surely there is some info on the net, breakdown drawing etc.
  10. The Following User Says Thank You to IchBautAuto For This Useful Post:
  11. #8
    Your insights are valuable. I couldnt find anything. Perhaps I wasnt searching effectively but alas...thanks again, though. Very helpful.
