Results 1 to 10 of 24
Thread: Airbag Recalls
    Default Airbag Recalls
    Hi fellow members,
    Since the announcement of the faulty airbag recalls, I have made sure to do my checks with my vin and rego with the dealer and other resources, after being told that my vehicle was not affected, I was shocked today as I have now found that I am affected.
    Today i had decided to visit https://ismyairbagsafe.com.au/ to do a check which showed I may be affected and to confirm with the Audi's VIN search. https://forms.myaudi.com.au/takata-recall?embeded=true also showed that I am affected
    Advise everyone to do a check even if you have done so previously in the past as I had also performed. No cost for doing your checks and being safe
    My recall is for my 2006 A4 B7 (Passenger Side only)
    https://myaudi-qrsolutions.netdna-ss...0Australia.pdf
    UPDATE - Just picked up my B7, process only took about a hour. Ecu tune is unaffected. The whole service lot was a B7 day :))
    Also had a complimentary Q5 loan car, make sure you request this when booking or you won't be provided with transport on the day.
    4,776
    Thanked: 470
    Thanks for that. I've put this as a sticky, and a copy in the Help Me section, so hopefully others will check also.
  3. The Following User Says Thank You to jnrdavo For This Useful Post:
    TheChenga (August 26th, 2018)
    Hi everyone, having my airbag recall work carried out today (2010 A3 TDI) am concerned that while they have the car they will do the software update for emission voluntary recall ....... which i do not want to occur. Has any one had any dramas in this regard?
    thanks for your help
    Any updates shouldn't disadvantage you. Do you have an ecu flash? Is that why you're not wanting any updates
    Aug 2017
    Crescent Head
    25
    Hi all. Have any B7 owners had their passenger airbag replaced as yet?
    Gone - Mondeo XR5. Yummy 5 cylinder goodness.
    Now - B7 RS4. V8 screamer.
    Various Mk 1 and 2 Escorts
    Quote Originally Posted by camRS4 View Post
    I have not yet been contacted by Audi Australia. The repair schedule is Nov-Dec. Make sure your contact details are up to date and registered with Audi so they can contact you to book in the recall work.
  8. The Following User Says Thank You to TheChenga For This Useful Post:
    camRS4 (September 25th, 2018)
    I get mixed messages re whether rs4 is affected or not. All the websites keep talking about A4, but the rs4 wasnít built with the a4 or even in the same factory?? It may well have used the airbag, but itís not helpful to put rs4 with a4 as itís really a different car.
    I guess I will just keep in touch with Audi...
  10. #8
    Quote Originally Posted by FUTQ View Post
    I get mixed messages re whether rs4 is affected or not. All the websites keep talking about A4, but the rs4 wasn’t built with the a4 or even in the same factory?? It may well have used the airbag, but it’s not helpful to put rs4 with a4 as it’s really a different car.
    Yes, RS4 is affected. Its uses the same passenger airbag as A4. RS4 is a variant of the A4 so to speak, alot of the interior parts are the same.
    Put your VIN into the following site https://www.audi.com.au/au/web/en/ow...ty-Recall.html
  11. #9
    FYI - I just got my recall email from Audi Aus.
  12. #10
    Just got my letter for recall stating that the Frontal Takata airbag inflator is subject to a Mandatory Safety Recall. Also states must be replaced by the end of 2020.
