Results 1 to 8 of 8
Thread: 18z conversion
    Default 18z conversion
    Has anyone on here done an 18z conversion to an Audi A4 b5 and what parts would I need to get?
    You need B5 S4 or B6 uprights wheel bearing housing as the caliper bolt spacing is different between the A4/S4. Not sure if there are adapters but that's the beauty of using the B5 S4 or B6 housings, it bolts right up with ML500 discs, RS4 brake lines.
  3. The Following User Says Thank You to jsol For This Useful Post:
    Carpo555 (September 20th, 2018)
    Canberra
    2,327
    Thanked: 267
    What wheels are you using? Fits under some 18 inch but not all. There is also a 17Z conversion uses something like 340mm rotors and is a common fix on the B5 S4. What jsol said about uprights etc.
    I've got 19inch wheels so I should be right,cheers
    You also generally need a ET of at least +45 (all wheels differ so this is not concrete) otherwise you will need spacers to clear the caliper.
    I
    I've got these rims
  8. #7
    Should fit no probs. Look good too!
  9. #8
    That's them on the car
