Results 11 to 13 of 13
Thread: Engine Fault
    Mar 2015
    Albion Park NSW
    124
    Thanked: 5
    Quote Originally Posted by jsol View Post
    I would physically check the aircon pulley/belt. If the bearings are shot the compressor it would be generating a lot of drag on the system. DBW cars utilize the ecu to step up the revs when the air con is switched on I think? Did you disturb the TB? It might need a clean or TBA.
    I havenít checked the aircon belt and pulleys today, Iíll do that when I come back from down the coast. I left the car at home instead of taking it. I did a TBA today and it didnít make a difference, Iíll clean the throttle body and do an alignment again when I get back home.
    If that doesnít work Iíll check the aircon pulley and belt and let you know.
    Mar 2015
    Albion Park NSW
    124
    Thanked: 5
    Hi mate,
    Finally got some time to get on the car. I took the throttle body off and gave it a clean, then did a TBA with my Ross-tech cable.
    Took it for a drive with the air on and car is running great again. As you said the throttle body needed a clean.
    Thanks again for your advice.
    Cheers
    No probs, glad you got it sorted.
  4. The Following User Says Thank You to jsol For This Useful Post:
    WollongongA4B5 (January 3rd, 2019)
