Results 1 to 10 of 11
Thread: WTB S4 B4 Aluminum thermostat housing
    Default WTB S4 B4 Aluminum thermostat housing
    Looking for an aluminum thermostat housing to replace my plastic one on my S4 B5, part number for aluminum housing is 078121121J. Let me know what you've got ASAP as I'm in the process of doing the timing belt now and want to get the car back together quickly.
    Sent from my Pixel 3 using Tapatalk
    Current: Nogaro 2001 B5 S4 Avant 6SPD - GET Stage 2+ Tune, Bosch 750cc Injectors, Walbro 450 Fuel Pump, Billy Boat 2.5" Catless Downpipes and Exhaust, APR R1 Diverter Valves, Bilstein PSS9 Coilovers, 034 Rear Sway Bar.
    Previous: Black 1999.5 A4 B5 1.8TQ 5SPD - Unknown Stage 1 tune, Turbo Back Exhaust, FK Coilovers, 710N Diverter Valve, Carbonio Intake
    Quote Originally Posted by Bainos View Post
    I guess one from the states will take too long for you;
    https://www.audizine.com/forum/showt...NUM-METAL-LQQK
    The metal one you want is the same as any ABC 2.6 (C4,B4,100, B5). If you can't find one I have one for $50.
    If you don't need yours I'd be happy to take it off you hands for $50 + postage, saves having to get it from the US
    No probs. I'll PM you later this evening and post a pic.
  5. The Following User Says Thank You to jsol For This Useful Post:
    Bainos (January 20th, 2019)
    Good buy. Scarce as hens teeth, at least the genuine ones. Most places out of stock. I bought two in late '17 and they were probably US $150 each.
    $50 only for fellow OzAudi members :)
    I've seen them regularly sold for $50-$60 US on AZ but after postage you'd be looking at around $100 AU
    Here's some pics. This is 078121121F but will still fit provided you either remove a 10mm bolt from the cam cover backing plate or clearance the tstat housing.
    I'll send you a PM Jsol.
    Seeing as US$60 is about AU$90, your shipping must be cheap. Most businesses are charging US$50 to ship to AUS. US shipping costs have at least doubled in the last 4-5 years. Sad days.
