Thread: VIC: Plastic Welders?
    Default VIC: Plastic Welders?
    Hey,
    So.... a few days back I was using a hammer to extract a screw from the valve cover, grip slipped and hammer knocked the engine cover mount ever so slightly and managed to crack it. Assessed the damaged and very fine hairline crack on the plastic intake manifold, enough to cause a minor vacuum leak and who knows how much boost PSI (Prestigious super injection) is being lost.
    Hoping I can somehow have it repaired via plastic welding or heat without removing the manifold. Currently have been able to dab some plastic weld epoxy on it which is holding with very careful driving.
    Any members experienced similar repairs and can point me in the right direction? A mobile visit would also be handy.
    Located eastern suburbs or west.
    Have found a local plastic welder that has repaired intake manifolds previously
