Thread: Google on MMI - Not enough data in memory
    4,765
    Thanked: 467
    Default Google on MMI - Not enough data in memory
    Hey guys, I keep on getting this error when trying to change from standard maps to google
    "Not enough data in Memory. Google Earth will switch to standard map display"
    Ok, fine, but how do I delete the old cache? Can't seem to find out how to do this on the interwebs..
    Bangor, Sutherland Shire, Southern Sydney.
    541
    Thanked: 58
    Just had this happen to me for the first time today as well.
    Not sure what the culprit is. Maybe the map overlays are a greater resolution not foreseen in 2012 when my car was launched.
    Have you found a solution?
    Without looking, as I havenít had time yet, you may be able to clear the cache from the green menu. If the maps are physically larger Iím not certain this will fix the problem though.
    4,765
    Thanked: 467
    no, not found the solution so far... Was even thinking about taking the HDD out and plugging in to my pc to see if I can clear out the old cache..
    541
    Thanked: 58
    It seems to be sporadic.
    Iíve had it happen twice and after leaving it for a minute or two and then reselecting google maps in the settings it seems to load up ok.
    Most of the time it works correctly, just happened twice in total over the last week or so.
