Thread: Coolant leak where the drain plug tube is
    Default Coolant leak where the drain plug tube is
    Hi
    Right after the engine pull, once i've put everything back together, i discovered a small coolant leak where the radiator drain plug tube is. I have capped it off for now but what would caused this? What do i need to replace or maybe i've over tighten it?
    Attached Images Attached Images
    2000 Avant A4 B5 Turbo Quattro - Powered by QMS E85 K04
    Sep 2006
    Fairfield Sydney
    1,298
    Thanked: 6
    Quote Originally Posted by Khoa View Post
    Hi
    Never even noticed that plug on the side.. i would check the threads or use thread sealant if application is acceptable for the plastic
    Sent from my SM-G965F using Tapatalk
    Now > 99 A4 1.8TQ (silver)
    Handling
    KW V3's | Hotchkies Front and Rear Sways | 320mm Brembo BBK |
    Power
    Garrett GT3076r 52 Trim 0.63 A/R| Haltech PS1000 (custom harness PNP) | Piper Ultimate Road Cams | Scat Rods | JE Pistons | Supertech Valve Set | IE Springs Set | Full Race Ex Mani | Custom Enlarged Intake Mani | 1000cc Inj | Zietronix Flex Fuel Sensor | Treadstone TR18 FMIC
    R.I.P > 98 A4 1.8TQ (cactus green)
    Quote Originally Posted by Gbomer View Post
    There is no plug there, i used a rubber grommet to cap it off, it just a tube there to release the coolant.
    Hey mate
    Might seem simple but have you checked condition of the little orings on the drain plug ?
    Sent from my SM-P555 using Tapatalk
    Quote Originally Posted by glenneaux View Post
    Hey mate
    You are correct, i went to the wrecker, got 4 of them and found that all i need is the little O ring.
    Cheers
