Thread: S3 8V unable to remove the rear pillar trim pieces above the parcel tray
  1. Default S3 8V unable to remove the rear pillar trim pieces above the parcel tray
    S3 8V MY2019 Sedan
    I'm trying to remove the two rear Pillar Trim pieces on the parcel tray cover.
    The MY2015 8V workshop manual says you need to pry out the SRS cover but I can't get it to budge.
    I've tried a thin flathead screwdriver, and a knife, but it seems sealed down. I just can't get into the side of the SRS cover to pop it up. It actually seems glued down.
    Did Audi change the design of it in the newer Facelift models?
    Maybe I just need to use force and rip the trip out?
    My 2019 trim:
    This is from a 2015 model
    S3 8V MY2019 Sedan
    Donít do anything by force or impatience, usually results in damages.
    Canít help sorry, not sure what youíre needing that for but if you got time keep researching. Try YouTube search or google it thoroughly.
    Quote Originally Posted by KAIS3R View Post
    Figured it out - just rip it out with force
    S3 8V MY2019 Sedan
    Sure, provided you know itís meant to be 😁
  5. Default
    Yep 😁
    Now I just need to figure out how the SRS cover clip goes back in.
    S3 8V MY2019 Sedan
    Hard to tell from that pic without seeing the whole lot, obviously a slide in mechanism but maybe the whole cover needs to come out and be reinstalled a different way.
  7. Default
    S3 8V MY2019 Sedan
