Thread: K04 inlet o ring.
    Default K04 inlet o ring.
    Hi Guys, Any one have any spare o rings that go over a K04 turbo compressor wheel opening, to seal the inlet pipe to turbo?
    Mine has come appart and cant get any from audi or vw as they don't stock them.
    Any one have an alternative o ring that will work? Not sure of the sizes etc.
    need a solution urgently.
    Thanks for any help.
    the part number I guess is 078133148 E
    2000 Audi
    S4 K04d
    2008 Yamaha
    R1
    Previous
    1996 Audi A4 1.8T Quattro
    1996 Nissan Skyline GTST *highly modified
    If you have a " Bearing Service Center " store near you...or similar...and you have the remains of the original O ring, they should be able to supply one. I had a similar problem on an aircraft engine on the inlet manifold, and they saved the day.
    Quote Originally Posted by BigBenny View Post
    Perfect mate, did exactly this.
    Uber'ed it straight to my door.
    If anyone else needs to know the size of the o ring is 44mm internal dia. with a 3.5mm thickness. (viton material so its rated to 205)
    Cheers.
    2000 Audi
    S4 K04d
    2008 Yamaha
    R1
    Previous
    Quote Originally Posted by 18TQ View Post
    Cheers.
    I'd only be wanting to use OE replacements mate.
    Sent from my CLT-L29 using Tapatalk
    2000 s4 ; noggy blue
    Cool
    Quote Originally Posted by RRAUDI View Post
    Lol, says the guy with franken turbos and fcp steering racks 😎
    2000 Audi
    S4 K04d
    2008 Yamaha
    R1
    Previous
