Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 64
Thread: Carbon clean RS5
  1. #41
    Default Carbon clean RS5
    Getting there
  2. #42
    What is the tool in the first picture & where did you get it from?
  3. #43
    Itís just the slide hammer and attachment for the injector
    They wouldnít go in by hand so use correct tools correctly.
  4. #44
    Nice, I pushed mine in with clean engine oil from memory.
    Any link to that kit on eBay would be great. Thanks
  5. #45
    Quote Originally Posted by mike View Post
    Did you oil the Teflon seal?
  6. #46
    It was a while ago now but I think was just the top part after the shaft wear it seats in the hole.
    Not the Teflon as that is there to provide a seal.
    Havenít had a problem since installation.
    B7 RS4 but it is basically same fuel injection system
  7. #47
    Quote Originally Posted by TYR382 View Post
    Is that including parts?
    I didn’t just do the carbon clean, while at I’m at it I’m going to do some major maintenance such as belts pulleys and so on
    Why not Iridium plugs? What is the recommended spark plug change schedule?
    2008 MY09 Ibis White Audi S5 Manual
  8. #48
    Worth remembering with spark plugs that any type will function. Copper is as good as any of the rare metals. What it's all about is life and reduced labour costs. I use copper in the RS4 and would cringe at the cost for a mechanic to change plugs every year. The downside of the ultra long life plugs is a lack of late life efficiency and worse, the chance of the plug seizing in the head if left for the full term. Then the few $ you've saved will be peanuts compared with a new head.
    C5 RS6: APR, Milltek & Wagner -- B5 RS4 : tastefully modified -- Audi 1.8 quattro 132 Kw -- UNIMOG 404 TLF8
  9. #49
    Quote Originally Posted by qman_au View Post
    Last I remember they donít make iridium plugs for this engine ( donít quote me )
    These are the factory oem plugs so Iím not too worried.
    Trust me the spark plugs are the lest of the worries when maintaining this engine lol
  10. #50
    The only seal that gets oiled is the top of the injector to connects to the fuel rail.
    The Teflon seal must be completely dry
