Thread: Custom clutch for 2.7tt/01E
    Default Custom clutch for 2.7tt/01E
    Built by NPC in Brisbane for me.
    Rated to 400kw
    Is brand new, includes throw out bearing.
    Flywheel is a used but resurfaced Southbend unit.
    Would like $850 everything. This is the same pressure plate that Mike Hood from ringer racing uses in his stage 4 clutches (his only clamps 2800lb from memory, this is 32 or 3400lb).
    Should be noted that it is both a sprung centre AND I had them leave the marcel springs in. This clutch drives like stock, if not better and will handle a fair whack of torque. No signs of slipping at 350wkw on a friends car and drove like standard.
    Sold.
