Thread: 2014 SQ5 brakes pads and rotors replacement
  1. Default 2014 SQ5 brakes pads and rotors replacement
    Hi All
    After 60k my rotors and pads (all corners) need changing. Other that OEM parts can anyone recommend where i can purchase these form within Aust?
    My local Euro workshop in Canberra that I go to told me about ATE rotors & ceramic pads.
    I am yet to replace the originals on my 2014 SQ5, but it is likely that I will go with those when I do.
    Therefore I canít really comment on how they are, but that they might be an option for you.
    Current rides: Audi SQ5, HSV E3 GTS, Ducati Streetfighter
    I used ECS supplied rotors from the USA with EBC Red Stuff pads and also fitted braided lines and new high temp fluid on my SQ5.
    Hard to determine which of the three component changes contributed the most to the excellent outcome but the entire brake system was much improved in terms of feel, power, fade resistance with the added bonus of almost no brake dust.
    Dingah
    Dingah
    2015 SQ5 TDI Sold
    2017 RSQ3 Performance Sold
    2018 S4
    Mrs B's Tiguan R-Line + APR
