Thread: Software issue?
  1. Default Software issue?
    2015 S3 hatch, 70K, just after a servicing I noted the following problems: -Proximity key doesn't work; must press the open/lock buttons to function
    -Every time I start the car I get a message: "battery low, will charge while driving"; my battery is new, less than 2 months
    -Back up camera doesn't work: when I shift to "R", the switch on the dash lights up and the side and back proximity alarms
    will activate but nothing on the monitor screen.
    -The automatic "engine off when stopped" no longer works.
    These seem like something got reset; there doesn't seem to be anything I can set to correct these problems. Any ideas?
    9,838
    Thanked: 448
    It all points to a battery issue. Did you use a genuine or aftermarket one as replacement?
    But none of these issues manifested for 6+weeks until the servicing.
    Apr 2017
    Melbourne, Victoria
    742
    Thanked: 113
    The start/stop engine feature points to a battery issue.. take it back where you serviced and get them to check it..
    MY18 RS3 Sportback | PP2 | Matrix | RSDP | Gloss Black package | Ara Blue | Opti Coat Pro+ | Tinting
