Thread: RS4 B7 engine damage
    Default RS4 B7 engine damage
    Hi all
    I have a B7 RS4 only 70,000ks, it appears there is a deep scratch in cylinder wall, no idea how this happened. They are suggesting that i may need a new engine - or bottom part anyway, as the coating will be too hard to repair. They are getting a specialist from Audi to check it out, however does this sound right?
    Cheers
    Sounds like a screw from the intake manifold flap runner has loosen and fallen into the cylinder. Plenty of info online about it happening to others.
    Not good news.
    5,006
    Thanked: 597
    Can you machine and sleeve these engines?
    Sent from my SM-G985F using Tapatalk
    Not common at all. Especially in Aus.
    I believe LA Sleeves and maybe Darton sleeves have one that fit.
    Unfortunately I can offer some first hand experience with this, had a scared cylinder from what was most likely a melted spark-plug.
    Looked at sleeves but with the man hours and accuracy required was simpler and cheaper to get a 'new' block from a wrecker.
    Unless you want to rebuild the block with forged components etc, I suggest doing the same.
    SC or NA?
    Sorry.
