Results 1 to 6 of 6
Thread: B6 S4 - slow oil drip from 'central gutter'
    Default B6 S4 - slow oil drip from 'central gutter'
    As the title says, I've had a very slow oil drip in my B6 S4. My mechanic says it's common and likely from a gasket leaking into the 'central gutter', and not identifiable / rectifiable without significant effort. He's done thorough inspections from the bottom up a couple of times and not found any obvious signs of a leak.
    Anyone have experience with this, specifically the 'central gutter' part of things? Totally new term to me.
    Cheers!
    Nov 2011
    316
    Thanked: 27
    Most likely valley pan gasket. I had that leak and it's hard to spot since it's under the intake manifold and will slowly drip down. In my case, I ordered the valley pan gasket kit with oil check valves & valve cover gaskets from ECS.
    Oil cooler is also a common leak location.
    You could also add some dye to your oil then try and locate the leak with UV light if you want to pinpoint the exact spot.
    B7 A4 2.0TQ
    8P A3 REVO
    B8 S4
    B5 S4 GIAC
    re: the UV option - if it's the valley pan gasket which appears to be buried fairly deep (as per the writeup here https://tinyurl.com/44wyj3hk), would the UV additive be see-able?
    Good info regardless, I'll see if I can't get that looked at - coming up on a 200k service anyway
    Nov 2011
    316
    Thanked: 27
    Should be able to see it from under the car if it's leaking down. It's a good way to eliminate other potential oil leak spots.
    B7 A4 2.0TQ
    8P A3 REVO
    B8 S4
    B5 S4 GIAC
    Just to close the loop on this, ended up pulling off the valley cover and simply having to replace a gasket.
    https://imgur.com/Gpv3QNR
    https://imgur.com/7mW3dL8
    5,441
    nice one!
