Results 1 to 10 of 24
Thread: Allroad C5 4.2 dreaded timing chain failure. Options?
    Default Allroad C5 4.2 dreaded timing chain failure. Options?
    So my 4.2 has succumbed to the well known timing chain guide failure common in the allroad 4.2 and S4 4.2 (B6 and B7) which share essentially the same engine, but not in the way you might expect. It’s an 04 with 205k on the clock, fairly well maintained and minimal mods. It has had the cam chain rattle for quite some time and I’ve been keeping up good oil to it, as per AUDIs recommendation for the fault. I was planning to do the chain guide work to it when it was convenient, but you know how that goes.
    My power steering pump started making horrible noises and failed, all very quickly. Seems uncommon, no leaks as reported elsewhere. Extracted the pump, what a pain in the arse as its driven off the rear of the engine by an auxiliary “gearbox” that is chain driven off the crank.
    Anyway, pump in hand, it turns smoothly and looks good except for the drive spline and the internally splined shaft that runs into the auxiliary “gearbox” which look abnormally worn and damaged.
    back under the car and I can turn the splined drive output with my hand and it feels loose and crunchy , I’m assuming that as everything in there is run from the timing and auxiliary chains that something has come away and played havoc.
    so now it looks like engine out for repairs to the auxiliary “gearbox” and of course while I’m there, the timing chain guides will be on the menu too.
    so thoughts? Do I just source the appropriate parts and repair what I’ve got? Do I try to source a motor that has already had the work done? Do I go for an S4 BBK motor (and 6sp box?)?
    2,347
    Thanked: 272
    You would be in line for a lottery ticket to find a recently repaired motor that is now up for sale. Happens I guess but a super long call. As for a motor replacement, it would need to be compatible with all your existing setup electronically or a possible world of pain redoing the loom or modifying ABS and the like. The surest solution is a repair but at some cost so you would really need to accept that it could be half or more than the car is worth. Suitably qualified people have done this themselves and there are some posts on here but not for the faint hearted.
    Well you never know what’s in the ocean until you throw in a line.
    the s4 BBK engine shares everything with the BAS except a few performance enhancers to net an extra 30kw. Dunno if the 6 speed gearbox is physically similar to my 5 speed but willing to do some research.
    I’d be doing the work myself, saving a wedge of cash. Owning an old AUDI means knowing how to twirl a spanner. I really do like the car, for better or worse, and I don’t like the idea of sending her off to landfill just for the sake of a minor indiscretion.
    5,172
    Thanked: 625
    there are a couple of videos out there from memory showing how and what to do with a timing belt change. From memory, there was one for a B7 RS4...
    2,347
    Thanked: 272
    Not to confuse the issue, there is the V8 with the timing belt (RS6 and early V8) and the V8 with the timing chain (B7 RS4 and allroad etc). I have seen something on video about the timing chain but it is a whole different kettle of fish to the belt service.
    2,347
    Thanked: 272
    Quote Originally Posted by GlennV8ar View Post
    Well you never know whats in the ocean until you throw in a line.
    Id be doing the work myself, saving a wedge of cash. Owning an old AUDI means knowing how to twirl a spanner. I really do like the car, for better or worse, and I dont like the idea of sending her off to landfill just for the sake of a minor indiscretion.
    Absolutely, you might improve your chances by including the non RS sources of that base engine. I've never looked at this specific swap so my comments are generic. If you obtained a full B7 RS engine and manual gearbox and ECU and loom you should really only have to check out the existing TCU interfaces to see if anything is dependant on TCU signals.
    If you can't get a manual gearbox then you may? have to change cranks to marry up an auto trans if the sourced engine was manual. Lots of transplants are possible with audi gear, it just helps to know all the little things in advance.
    No rubber band drive here. It’s “lifetime” chains, unfortunately “lifetime“ can be anything from 80k to 300k. Also to clarify, it’s the S4 not the RS4 that shares the most similar engine. As nice as the 300kw+ BNS engine of the RS4 would be, the more humble 254kw BBK and 6speed tiptronic from the B6 and B7 S4 would be more than adequate not to mention actually affordable.
    You need to have the engine out first to ascertain what you need. Ive done a couple. Chain rattle doesnt always mean broken guides though it isnt uncommon to have no rattle but still have broken guide/s. The rattle is usually loss of oil pressure in the mechanical cam adjusters due to failed check valves in the valley pan. I would change them first and see if that fixes it. A lot of people (myself included) run an accusump instead of relying on the probe to fail check valves.
    If the rattle is still there then you need to pull the engine and trans. There are a few different guides that fail. With it out you then need to check the condition of the locking pins inside the cam adjusters and the solenoids. The chains wont need replacing.
  10. The Following User Says Thank You to jsol For This Useful Post:
    GlennV8ar (July 5th, 2021)
    I’m thinking that after 200k I’m inclined to pull the engine/box out and check/replace the lot. Aside from not really knowing the extent of the power steering drive issue, I want to know exactly what’s going on inside.
