Q. did you test the level sender against the fuel gauge (ie hooked up normally) while it was out of the tank?
Ground for that one should be the earth lug on drivers side of under dash just above the bonnet release lever
Another resource if you haven't checked already is VDO gauge sender troubleshooting charts, VDO likely made the sender in the tank and possible the cluster gauge too. The charts will list malfunction indications.
'99 Quattro, stroked 2L
Concept, tune and build by QMS
EFR 6758, Bosch 1000cc, E85 @7bar, Bosch 413 in 034 surge tank. VVT cam timing upgrade. Controls by Eurodyne boost manager, V8 MAF, LC1, EGT. JE 9:1, 13kg 2L Crank, 475gm rods, Ferrea , Dowel pin crank, IE tensioner, 034 Pheno Spacer, FX400 240mm x6, Apikol SMIC, Miltek 2.75 Koni coils, Stoptech BB, Powerslot Rear, SS lines, 034 G/b, Apikol Diff mounts, APR snub mount.
