Thread: B7 RS4 Avant boot gas strut issue
    Default B7 RS4 Avant boot gas strut issue
    Hi All
    In a bit of a pickle with my right hand side gas strut mount. Over time it was getting looser and looser until recently I attempted a fix using a Plusnut which did not work as the force of the strut has again ripped it away.
    So now, I am wondering if I can put a plate behind the hole to strengthen it and use a standard washer and nut on the back. Question is, in the pic below, can I drill an access hole somewhere in the red circle in order to access the strut mount?
    Current: 2006 B7 RS4 Avant in Imola
    Previous: 2004 A4 1.8 Turbo Quattro
    APR Stage 1 | Bilstein PSS9 Coilovers | Remus Exhausts | 18" RS6 Reps | Brushed Alum Mirrors | Phatbox | RS4 Pedals | RS4 Gear Knob
    Canberra
    2,345
    Thanked: 270
    Personally I'd try another option. I'll look at putting pen to paper later today and PM you some suggestions.
    Jan 2009
    Blue Mountains, NSW
    2,032
    Thanked: 53
    If you can somehow get into the cavity, I'd do a large-ish square plate, as big as the red circle, 3mm+ thick, pop riveted in at the corners. Then the ball joint through the plate, into welded in nut. 4 rivets distribute the point load.
    2004 A6 C5 Sedan 3.0 V6 Quattro
    1999 A4 B5 Avant 2.4 V6 (Unreg)
    Retired:
    1990 100 Sedan 2.3
    1991 90 Sedan 2.3
    1999 A4 B5 Sedan 2.4 V6
    2005 A6 4F Sedan 3.2 V6 Quattro
