Thread: Carbon Fibre Trim re-glue
    Apr 2009
    Perth
    157
    Thanked: 2
    Default Carbon Fibre Trim re-glue
    My carbon fibre trim around the shifter is coming unstuck mostly because it appears the outside layers are shrinking and causing it to curl away from the console. I can force it back into place but it springs back so I'd need a pretty serious glue to hold it down. I can probably clamp it while it dries.
    Does anyone know what would be a good glue to use?
    5,554
    Araldite is probably your best option.
  3. The Following User Says Thank You to jnrdavo For This Useful Post:
    Iwant1 (October 8th, 2021)
    Apr 2009
    Perth
    157
    Thanked: 2
    If I apply a little heat from a heat gun will the Carbon fibre be a little softer and able to be moulded back into shape?
    5,554
    I'm not sure on that one... risky, but might work...
