Thread: Wanted v10 RS6 engine
    Jan 2007
    canberra
    305
    Thanked: 4
    Default Wanted v10 RS6 engine
    Hi guys, I need a v10 engine from a v10 Rs6, mine has a hairline crack on top of 1 of the pistons, and I have been told to look for a second hand engine as itís cost prohibitive to rebuild.
    Thanks I will be paying in cash.
    Call or msg me if you know of or have 1 for sale Joseph 0413195836
    Oct 2009
    Northern Beaches, Sydney
    487
    Thanked: 14
    You would probably be best to look for one over in Europe (particularly Germany) as you'll struggle to find one here in a reasonable time frame.
    I just bought a C7 RS6 4.0tt that's got low compression in cylinder 1,
    they were in the same situation as you & had to import a replacement 2nd hand engine from German due to it being cost prohibitive for them to rebuild it.
    07 Porsche cayenne turbo 580hp, 00 A4 widebody track car 4.0tt v8 RWD, 00 Avus S4 MTM Stg 2++ 350Hp ​back , 1954 GMC 9500 ratrod truck, 1982 Chev C20,
    Previous:
    85 Ford F150 Air Bagged, SFBD'd & sectioned on 22's (bushfire burnt to the ground &#128546
    08 H1 Hummer 4x4 rep 6.4L 470-500Hp
    04 Ford Xr6 Turbo Ute 1067Hp / 71 HQ 2Dr GTS Monaro s/c LPG 350Chev 400Hp
    Wide body Candy blue VIP Lexus , 79 Alfa 2L Gtv(track car), 73 Lx Torana 400Hp, 95 A4 RWD widebody, 00 A3 1.8t,
    Aug 2015
    Adelaide
    679
    Thanked: 31
    Highly recommend you to just to conduct a partial rebuild.
    1. The chances of you finding one cheep enough in Australia is very slim so importing one from another country is going to cost you the $$$
    2. Even if you were so source a second hand unit, the reliability state is at huge question and ya probably just going to have to rebuild it anyway.
    3. You want to do as much as you can to keep the original engine as Munich as possible to keep the resell value up, A car with a rebuilt original engine is far more then a car with a second hand engine.
    4. Rebuilding your engine will guarantee the reliability and peace of mind when driving it.
    Unless you have severe block damage, I highly recommend just to drop ya engine and do a good inspection on everything.
    When ever owning a V10 in any form itís always going to be two types of people who should own them. Rich people or mechanics.
    I fully recommend just drop the engine, do some inspections to see if anything has been damaged.
    If its just one piston its not a big deal. Yeh ya going to have to strip the head but at the same time you can do a lot of preventative maintenance while ya at it.
