Thread: Cargo restraint in boot 2006 Q7/ Water in AMP.
    Default Cargo restraint in boot 2006 Q7/ Water in AMP.
    Hi, I am trying access the amplifier in the boot of a 2006 Q7. The later models have tie down rings bUt mine has a sliding chrome channel on both sides. Does anyone know how to remove these channels? I cannot access the water damaged (I think) amplifier to try a fibre optic loop. Any help or advice would be greatly appreciated. Also will the VAG computer tell me which audio component of the MMI is faulty?
    10,082
    Thanked: 477
    Normally there is bolts concealed either in or alongside the rails. You'll likely need to remove the rail before you can remove the side trim to get at the amplifier.
    A diagnostic scan will reveal if the amp is online or if it has dropped out of the system.
    Default Q7 boot cargo strip.
    Thanks Alister. I couldn't see any but I will check again in the morning.
    Rod
    Blue Mountains, NSW
    2,092
    Thanked: 57
    The water in the amp is for the sub in the boot. (Sorry, can't help myself.)
    1999 A4 B5 Avant 2.4 V6 (Unreg)
  5. The Following User Says Thank You to broke90 For This Useful Post:
    IchBautAuto (December 20th, 2021)
    2,457
    Thanked: 280
    Quote Originally Posted by broke90 View Post
    Levity is good! Tis the season.........
    Blue Mountains, NSW
    2,092
    Thanked: 57
    You get to a certain age and the dad jokes just kick in.
    2,457
    Thanked: 280
    Glad you said that, I was thinking just the same or was it Steptoe and son. Now to hope that all this facilitates the location of the rail securing device.
