Thread: B7 RS4 - New spark plugs
    Default B7 RS4 - New spark plugs
    Morning all, and happy new year
    Time has come to change the plugs on the RS4. Sounds like these are the OEM ones and are around $20 to $25 locally per plug
    https://jhmotorsports.com/spark-plug...-5-2l-v10.html
    Just wondering whether i stick with these ones or try something else?
    Also, will change them myself as there are plenty of DIY guides out there.
    5,442
    I can't see anything on the APR website that says that you should change from stock:
    APR ECU-27T APR ECU Upgrade - 2.7T EA835 V6 (goapr.com)
    2,445
    Thanked: 280
    The standard plugs are OK, if you change brand or heat range make sure you are on top of any limitations with different plugs. The long life plugs save money on plug changes every service and bring the occasional problem of plugs seized in the head because they haven't been removed for years (and years). Alloy head = major repair if it goes haywire.
    C5 RS6: Sportec, Milltek & Wagner -- B5 RS4 : modified -- B5 Audi 1.8 quattro 132 Kw -- 2007 VW Touareg TDI -- UNIMOG 404 TLF8
    May 2008
    847
    Thanked: 52
    I purchase these below from Paul at VAGPARTS. Great guy & supporting a local small business.
    Send him a email & he will bundle 8 plugs for you.
    https://www.vagparts.com.au/products...62d939ad&_ss=r
    That is the standard temp range if running a stock motor ie no blower or turbo.
    Thanks for the replies
    I'll hit up Paul from VAGPARTS, thanks Mike
    Jan 2022
    37
    If you’re not tuned, just keep the oem, basically are NGK so it’s a good brand. Just change them way before than Audi says
    Apr 2013
    1,396
    Thanked: 143
    Quote Originally Posted by ManuTT View Post
    Why?
    Dingah
    Dingah
    2015 SQ5 TDI Sold
    2017 RSQ3 Performance Sold
    2018 S4
    Mrs B's Tiguan R-Line + APR
    Jan 2022
    37
    Regard the brand, they can keep up even a soft tune..
    regard the km, even a 0,01 gap makes the difference, and with engines like yours or tuned, it’s advisable to change them sooner than Audi recommends. They’ll be way more used than that gap if you change them after the normal service.
    no damages to the engine of course, but hit a rougher idle, very small fuel consumption differences etc..
    also, more power, more heat for the spark plugs, more prone to fail if it’s not correct..so no one wants a spark plug part into the combustion chamber!
