Thread: A4 b8 mmi upgrade
    Default A4 b8 mmi upgrade
    Hey i have 2g low red display and cluster
    I can buy 3g high from a5 all complete with all instalation cable and cluster.
    Do i need some other instalation wiring?
    Will cluster have my mileage or the mileage of car from what it is?
    Poslano sa mog SM-A526B koristeći Tapatalk
    10,031
    Thanked: 477
    I think you'll require the 3G main unit, control panel, screen, gateway, amplifier (if you have a sound system such as B&O), and cabling at a minimum (potentially cluster too).
  3. The Following User Says Thank You to Alister For This Useful Post:
    mariokovacic12 (January 11th, 2022)
    I will get all parts of radio system i got standard speakears no b&o
    I will also get cluster
    5,442
    Do a search and look for a guy called Keldo who will be able to assist.
  6. The Following User Says Thank You to jnrdavo For This Useful Post:
    Where can i search for that guy?
    Is this the harnes i need to conect it properly?
    https://a.aliexpress.com/_mt10L9i
    I got all the parts of radio system
    And order kufatec harnes 40105 (130)
    All is plug and play only amplifier conector must bee cut and install new one
    If you have chorus concert symphony you will need diferent harnes
