Thread: Car Front Lights - Scratch removing
    5,500
    Default Car Front Lights - Scratch removing
    So, was bored the other day with the S3, as I can't get the engine to work!! (see other thread).
    So I decided to do something that I know I could get to 'work', and went about removing the scratches from the front lights.
    The car has had a busy/rough life prior to me, so needed some love and affection.
    Lights before (I didn't seem to take a log of the 'before' photos !):
    Lights After:
    I used 800 gritt wet sandpaper, then 1500, then 2000... Then I buffed it with various compounds, then a final coating in some wax..
    Hopefully makes the car look less tatty
    Jan 2021
    63
    Thanked: 3
    Brilliant result there mate! It's so satisfying getting scratches out of anything. If you've got time and want a little challenge, probably worth a clear UV tint to protect the headlight (longevity) as you've sanded back a layer.
    5,500
    Yeah agree, something I can look at getting.
    10,052
    Thanked: 477
    Great job Stu. The lights have come up very nicely.
    I would be looking at 2k clear coat in a rattle can to protect the lights.
    5,500
    That's a good idea too alister.. An I actually have some at hand!!
    I've currently put on some 'wax' that I had, but not sure if that will burn off, or last at all... It was something at least..
    Aug 2015
    Adelaide
    729
    Thanked: 31
    Did you use a sealant ?
    5,500
    Only some wax I had at the time.. car is not drivable yet, so not an issue. I have some 2k clear that I might use.
    Aug 2015
    Adelaide
    729
    Thanked: 31
    You eventually will need to put a UV sealant on it. The meguiars clear is pretty good. Done a headlight from the wreckers with stuff turned out awesome.
