If you know the battery to be undersized/under spec I would start there.
Hi All
Have had this issue for a number of years now where after leaving the car for a few days the start can be quite lazy. Push the start button, then nothing for say 5 to 10 seconds then it fires up.
However today, I could not get it started. Press the start button and I could hear a few audible clicks. Nothing.
Checked the battery and it was sitting at 11.7V. So I hooked up my portable battery charger. Turned over the key and it instantly fired up.
So I got the battery replaced in 2019 and at the time we looked in the Delkor catalogue and selected the battery that suited the car. However, this battery was physically smaller than the previous OEM Varta battery.
I had a look again today on the Delkor website and it quoted a different battery to suit the car, and one that physically would be the same size as the OEM. Here are the specs on what should be fitted to the car
Here is the battery in it at the moment.
To me, it's clearly the wrong battery.
So a few things here.
1. Do I replace the battery as a first port of call?
2. I've read that the symptoms I am experiencing are due to a problem with the starter motor. Should I replace that?
3. Maybe I have some kind of parasitic drain going on here and an Autoelec should check it out.
Thoughts?
If it is anything like my cars, the more exotic the spec, the quicker the battery drains. My A4 will sit for months without dropping below 60% whereas the RS4 is less and the RS6 less again. I have a cetek battery monitor on every car and you can log the drop in volts if you just open the door. The alarm and convenience modules are current users so the more you have, the more you use, 24/7 even when you sleep. Irrespective of use I have my cars on a charge every 2 weeks. There is nothing wrong with your starter motor if it kicks over with a fresh battery. 11.76 volts is a dead battery to all purpose. Get a new one, best you can afford and maintain it like your life depends on it. Just grab a glass, sit and think of the systems in your car and it will quickly become obvious why there is no correlation between your car and the same battery in a 1960-70's car where it is tootally isolated from any current draw (if you remembered to turn the lights off)
When the battery died in my RS4 I opted to go like for like and bought a Varta. A fully charged SLA, sealed lead acid, battery cell voltage is 2.2 volts per cell, so a fully charged battery will be 13.2 volts. The other thing you need to consider is the CCA, cold cranking amps, capacity. If you are buying an alternate, CCA capacity needs consideration.
If you have a charger with a reconditioning function charge the battery with that function, that can revive slightly sick batteries. I run Ctek chargers on my cars but this will not stop a battery from failing. My RS4 battery dropped a cell while on the charger, the charger then goes into current limit still trying to charge the battery.
Get a load test done on your existing battery, that will give you some idea of battery health. Parasitic drain is not hard to check just time consuming, a DC tong, clamp tester is the best tool to use.
Current - 1984 WR Ur Quattro
I’ve had issues with battery In the past from an old tracker that had a backup battery that was killing my main car battery.
Once I pulled the old tracker back up battery out that solved an issue with my new battery not having enough charge to start car after 1 week.
I also thought that I had an issue with starter motor as well but that wasn’t the case.
I would start with the cheapest option and that is put a ctek on it when your not using the car. I bought the MXS 10.0 and that can completely recharge battery over night if it is flat.
Yes, you could put a bigger battery in with higher CCA but I think a ctek on it could help a lot.
I do believe there is a parasitic draw with my car but between the aftermarket head unit, amplifiers and the S/C coolant pump that runs on for 20 min every time I stop the car it is easier for me to charge and top up the battery every couple of months.
I also carry a Noco jump pack in the boot all the time just in case I need it.
Thanks for the replies everyone
Mike, with the ctek, you just hook it up and leave on charge whenever you are not using the car? You just hook this up on the terminals under the bonnet?
I see Repco has the MXS 10.0 on sale at the moment so might grab one.
Sent from my SM-N975F using Tapatalk
I’ve got the pigtails that come with ctek hardwired to the battery in the boot all the time and use that when it’s easy access. I.e boot isn’t full of crap.
Otherwise under the bonnet with the alligator clips onto the battery post under bonnet works fine as well. You can sit ctek on LHS rocker cover and still close bonnet fully without any issues so you can still lock car and leave on charge if required.
An alternative is to use the Ctek fitting that is installed in the trim. Just pop the boot and plug in the MXS 10. I have a couple of these fittings for the RS6 and Touareg where the batteries are not easily accessible. Plus a few chargers. I put mine on every two weeks. I have left the Ctek on for a few weeks but I am not totally confident in the software once it goes into maintenance mode after about a week so prefer not to use it like that.
I've just got mine sticking out of the boot bottom (internal) and plug the connector in to that..
The problem is that I've driven away with the charger still connected twice now... So much so that last time it striped the connector. I've had to put on some electrical 'connectors'. AND, I've driven away with it connected again, but this time is just pulled apart the connectors, job done!
