Thread: Q5 tfsi 2L EPC light.
    Default Q5 tfsi 2L EPC light.
    So I scanned it with OBDELEVEN and it’s saying turbo positioning sensor. It is only intermittent coming on under light excaleration.
    If I drive it hard no light comes up.
    Question? If I change out the actuator does it need to be coded with VCDS or alike. Cheers Simon
    5,775
    normally changing a part does not require new coding in vcds, just clearing the error codes.
    Some interesting reading here, where the potential same error was actually a leak..
    Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal | Audi-Sport.net
    Ok cheers.
    Thinking I just change the actuator then. Mine Is petrol and occasionally the electric actuator arm stays out. I could drive for ten minutes and it will happen and other times a hour or two. When I turn the car off it retracts back in no problem.
    I’ve cleaned and checked all wire connections and de carbon the turbo veins. Also clean the MAP sensor.
