Hi all, I have a strange Intermittent not starting issue and wondering anyone has any idea on how to fix? Would be grateful.
Around 1 in every 5-10 times, you press the RS4's starter button and it just wont start. No sounds at all (aside from the fuel pump pressuring the system), silent, no ticking, no error lights,
the lights do not dim when I try to start it. Plug in a scanner and no fault codes, just silent. Tried different scanners too. 0 current or pending faults. I have a c-tek battery sense checker and the battery voltage is reading well within normal range for a AGM battery which it has. The battery's been reading as high as 80%+ when this issue happens.
If you lock it up and leave it for 5 minutes, then come back, it just fires up like normal. weeeeeerid. No other issues, cars in perfect working order.
It seems to happen more often when the car has been left for a few days, not sure if that's a clue.
I've taken it to Hitech Automotive Centre on Gardeners road in Mascot who are a auto electrician and seem really good in the past, and have a good reputation. They had the car for 2 weeks, tried to start it every day and it started for them each day, and their scanner showed no errors logged. So after 2 weeks they were completely unable to recreate the problem and had to hand the car back.
Starter motor is original as far as I remember, so are solenoids.
Clutch in sensor has been checked as fine by previous mechanic.
I've pulled the starter button out, all connections look good, infact I replaced this with a new one for cosmetic reasons just a few years ago.
I'm not sure what to do to diagnose further as its so hard to recreate the problem and when you do, no errors. I'm reluctant to jump straight in and stat replacing things like starter motor and starter solenoids due to the costs.
Anyone with some electricals experience, I'd be very grateful for some advice?
ideas of what's at fault:
Immobiliser
starter motor or loose connections to it - this thread pointing to starter motor
https://www.audizine.com/forum/showt...starting+issue
starter motor solenoid - Solenoid is integrated into the starter on this model I've read
Grounding issue
clutch in sensor - at the clutch pedal
starter relays - under the drivers knee bolster, post here on someone resolving the problem with the starter motor relays:
https://www.audizine.com/forum/showt...1#post13991772 and fuse box diagram:
https://fusesdiagram.com/audi/fuse-b...udi-a4-b7.html
Varta H15 (DIN100L) AGM Battery not good enough?
