2002 Audi TT 8N 1.8T: whole car goes dead (no dash, fan, or locks) when I try to start after using a diagnostic cable. It recovers after disconnecting
teetee
Car: 2002 Audi TT 8N 1.8T quattro 225, ME7.5
What’s happening: Over the last few days I’ve been testing a KKL cable with some diagnostic software. Afterwards, when I try to start the car, the dash lights normally with the ignition on, then everything goes dead as I turn to start. No dash, no fan, no central locking, nothing. It has done this several times now.
What I’ve ruled out:
  • The adapter was not plugged in when I tried to start. I unplugged it first, then turned the car off.
  • The battery tests fine [say how: multimeter reading, or a load test].
  • It has happened with different cables, Bluetooth dongles and software.
  • I did not clear any fault codes.
How it recovers: after the battery has been disconnected for a few minutes, everything comes back and the car starts normally [say whether it starts, and whether anything is reset or throws codes].
Context: in the last session the engine was running while the cable was connected. I read data only [and a few signals on the K-line wire].
Questions:
  1. Has anyone had the car go dead like this after using a diagnostic adapter, and what was the cause?
  2. Could the OBD port wiring, its power feed or fuse cause this? Which fuse feeds the port on an 8N?
  3. Any ideas what latches the electrics off until the battery is disconnected? Gateway or comfort module, a main relay, the ignition switch?
Happy to post fault codes or measurements if someone tells me what to check.
I don't know if this helps, but this was from Copilot.
Fact-Based Diagnostics for 2002 Audi TT (8N) ME7.5 Electrical Total Failure
* The Cause: Turning the key to the start position draws maximum current (~150–200+ amps). High resistance at a main connection acts as an open circuit under this load, completely killing all terminal 15 (ignition) and terminal 30 (permanent) power.
* The OBD Connection: The diagnostic software or KKL cable cannot physically or electronically "latch" off the entire vehicle infrastructure (central locking, fans, cluster). The physical act of plugging/unplugging the adapter moves the lower dash trim, which directly vibrates the ignition switch harness and main busbars (Relay Panel 1).
* The "Reset" Illusion: Disconnecting the battery does not reset a module to fix this. The physical movement of pulling the battery terminal mechanically shifts the loose terminal connection or moves the notorious under-battery chassis ground strap, temporarily restoring the contact circuit.
* OBD Port Fuse: The OBD port (Pin 16) is permanently powered by Fuse 12 (7.5A) inside the cabin fuse panel. Because your cluster illuminates prior to cranking, this fuse is completely intact.
* Primary Culprit Targets:
1. Battery Fuse Box: Check for melting or micro-cracks on the black plastic fuse block sitting directly on top of the battery casing.
2. Chassis Ground: Corroded main ground connection located under the battery tray.
3. Ignition Switch: Cracked internal plastic housing on the electrical ignition switch behind the key cylinder.
Would you like the specific multimeter test points to check the next time the car goes completely dead, or the part number for the replacement ignition switch?
Not sure it's that, the car is completely dead when it happens, and it's always only after using the OBD. Battery is a few weeks old , well charged, etc.
Left the battery connected overnight, dash lit up as normal with key position ON , soon as I try to start everything turns off. no longer any lights or noises at all. Pulled battery, waited few minutes, plugged back in and she started perfectly
I would suggest stop using the the obd for a few weeks, and 100% confirm that that is the issue.
If so, then you probably need an auto electrician to do some root cause finding on the obd port...
