Hi all,
I’ve just bought a 2013 SQ5 TDI at auction and it has a pretty bad coolant leak into the engine valley. No obvious drips on the ground, but the coolant level drops around 400 ml after only ~10 minutes of driving.
I’m planning to pull the intake manifold to inspect and work out what needs replacing (EGR cooler, plastic coolant fittings, bypass valve, oil cooler seals, etc.).
Thanks in advance.
- What’s the best step‑by‑step guide or write‑up for removing the intake manifold on the Gen2 3.0 TDI (2013 SQ5)?
- Can the EGR be disabled via software (or another method) while leaving all the hardware in place? I’d like to keep everything looking stock for registration/inspection here in Australia, so a full physical delete isn’t ideal.
Thanks in advance.
