2015 audi q5 (8r) integrated heated seat retrofit with aftermarket controls
Autofidelity
COMPLETION DATE: - July 2015
PRODUCT NAME: - Integrated heated seat retrofit with aftermarket controls.
BRIEF PRODUCT DESCRIPTION: - Seat heating for the two front seats with high, low and off settings. The switches are mounted neatly on each seat for easy access.
VEHICLE TYPE: - 2015 Audi Q5 8R
OTHER COMPATIBLE VEHICLES: - The entire Audi range!
ASSOCIATED PRODUCTS:
Heated Seat Retrofit with Genuine Controls for Audi A6 4G
Heated Seat Retrofit with Genuine Controls for Audi Q5 8R
MORE INFORMATION:
For enquiries and bookings, please visit our contact page.
Also check out our
Autofidelity is located at 26-28 Kilpa Road Moorabbin, Victoria Australia 3189, please click this link to access directions.
Hi,
A couple of options that you might be able to consider.
Kufatec advertise new lights to suit your vehicle. You can have a look at the following link:
https://www.kufatec.com.au/shop/en/audi/q5/q5-8r/bi-xenon-led-headlights-audi-q5-8r-w-daylight
We may also be able to source you some good second hand lights locally, which would be more cost effective.
Either way, we recommend that you also use auto-levelling and upgrade the central electronics module in the car. Technically, headlight washers should also be installed, but not many people bother. Here are some other links that you can check out:
https://www.kufatec.com.au/shop/en/audi/q5/q5-8r/auto-leveling-headlights-retrofit-audi-q5-8r
https://www.kufatec.com.au/shop/au/...central-electric-Highline-Audi-A4-8K-A5-8T-Q2
Bi-Xenon Headlight Retrofit Upgrade from Halogen to Bi-Xenon Headlights for Audi Q5 8R | autofidelity
If you have only just started looking at lights, be careful of Left-hand-drive lights from the US etc. You should only use Right-hand-drive lights in Australia.
There may also be some aftermarket options around the place, but we haven't been impressed enough by the quality of those products to recommend them. If you are after something like this, maybe check out Mars performance.
Hope this helps.
We normally get these in on request, so unfortunately none in stock right now. We should be able to find some for you if you need them.
