Hi everyone,
I’m hoping someone with experience on the B9 A4 can help me work out what might be causing my air conditioning problem before I spend $2,600 Aud replacing parts that may not be the issue.
I have a 2017 Audi A4 B9 2.0 TFSI quattro. The air conditioning was working perfectly before the car went to mechanic for a oil change and service.
During the service, a mechanic broke a coolant line connected to the coolant reservoir at the rear of the engine bay. Coolant spilled over the top of the engine and surrounding area, and the coolant reservoir emptied. Mechanic repaired the line and cleaned up the spilled coolant.
During the cleanup, they unplugged various sensors and electrical connectors around the engine bay to check for coolant and clean the affected areas. I don't know exactly which connectors were unplugged.
Immediately after picking up the car the air conditioning wasnt blowing cold air. Took it back to the mechanic where they performed an ECU reset to try to resolve issue, the A/C buttons then became greyed out and I can no longer switch it on. The heating still works and fans blow air.
I have now taken the car to multiple mechanics but none of them have been able to pinpoint the exact cause.
The fault codes and diagnostic findings so far include:
- B109E13
- refrigerant pressure test showed excessively high low pressure 350 psi
the A/C system was not running as is locked out the gauge readings were approximately 350 PSI on the low side and 140 PSI on the high side. The mechanic has drained the refrigerant from the A/C lines to prevent possible compressor or line damage.
The latest mechanic suspects the compressor has failed and has quoted around $2,600 to replace the compressor and TX valve he says might be stuck open. However, he said he is not 100 percent this is the cause and next step would be a whole new ac system.
Is there a reliable way to confirm the compressor has actually failed before replacing it and confirm it not a sensor, wiring, or adaption needed issue.
I’m approximately four hours from the nearest Audi dealer. I’m trying to narrow this down before arranging transport or spending a lot of money.
I’d really appreciate advice from anyone who has dealt with B109E13, compressor lockout or similar issues on the B9 platform.
Thanks!
- B109E13
Thanks!
