Hi all,
I have an Australian-delivered Audi SQ5 8R 3.0 V6 BiTDI diesel, 2013 build / 2014 compliance.
The car has already had major maintenance done, including timing chains, injectors, tappets, water pumps and related work. I’m now looking at the next stage of sensible upgrades.
At the moment the factory airbox is damaged. I can buy the OEM replacement through VAG, but before I spend money on a standard replacement, I wanted to ask whether anyone has found a better aftermarket option for the BiTDI platform.
This is the diesel BiTDI, not the 3.0T supercharged petrol SQ5, so I’m trying to avoid the usual CTS/IE/APR petrol intake rabbit hole unless someone has actually made something work on the diesel.
Areas I’m considering:
- Airbox replacement or upgraded intake
- Radiator and charge cooling improvements
- Additional oil cooler
- Engine bay harness tidy-up
- Extra monitoring/logging via sensors or Raspberry Pi-style setup
I’m comfortable doing some of the electronics and integration myself. For example, I’ve already upgraded the MMI spinning hard drive to an industrial SSD.
The main ask is:
Before I buy the standard VAG airbox, has anyone found proper aftermarket parts or a better upgrade path for the 8R SQ5 3.0 BiTDI?
Interested in first-hand experience, part numbers, supplier links, photos, suitable donor parts, or workshops that actually know these cars, or literally anything, i often feel like i was the only person who has purchased one of these
The main ask is:
