Audi A3 8v Turbo Actuator Problem
ILTShadow
Hello, I got an Audi a3 8v s line 1.8t quattro 132kw,
engine code when scanned: P256300 Turbo Charger boost control position sensor circuit range/performance
Had Epc light, replaced the turbo waste gate actuator and put it at 3.75v range. I have a calibrate button on the scan tool and when i clicked it the turbo actuated 9 times back and forth then the scan tool said aborted safety reasons so i thought if i just put it at 3.75v the car will realise when no throttle is applied and will call that one endpoint, and when i full throttle it will call that another endpoint. Anyway there was No epc light and i had full boost, drove for two days then all of a sudden epc is back. When i checked the scan tool it said the v was at 4.4v. At first i thought i didn't tighten the bolt enough for the waste gate to keep the rod in place, but when i checked it was tightened, whats more i actually loosened it and readjusted the gate to try get it back into range, but i found after only a small amount of adjusting i had reached the end of the waste gate screw hole, so i couldn't screw it anymore, and yet it was still at 4v (not in range). But i turned the car on and again no epc. So i thought maybe smth else is wrong.
I decided to drive it again and keep scan tool on to track live actuator and boost data. Drove a bit and it was fine for a bit, voltage range stayed the 4v mark. Then i did some spirited driving so i can get boost data and found the actuator still goes properly from 4 to 0.87v but the boost seemed good(1.85bar including the 1atm of pressure so only really 0.85bar of boost). During the ending part of my spirited driving all of a sudden epc back on mid drive, checked the scan tool at ecu clearly opened the gate to 0.87v so that turbo wont engage for safety reasons. As well as this the voltage is back at 4.57. One more thing is the upper and lower stops for the waste gate did change when the waste gates actual voltage changed. As in when the actual position voltage went from 4v to 4.4 the upper stop also changed to 4.4ish, and the lower stop is no longer 0.87 but in the low 1's instead
Right now i am thinking there is some feedback loop where the actuator is slightly deviating (for some unbeknownst reason) and the upper stop then compensates to be in the region of the turbo since that's what's considered the closed position.
Also i did try reading the v at car off position, car on and car at operating temperature and got the following numbers respectively 4.04v not on, 4.01 on and at operating temperature, Which to me sounds fine since the temperature sensor in the hall effect sensor of the turbo actuator recalculated the magnetic field based on the ambient temperature to get a right value, But i am seriously stumped
If anyone knows anything please help!!!
thanks
It could be wastegate arm play..
Any movement = turbo pivot wear.
