yellow hot rod
Shed clear out. I sold the S4, so I no longer need the parts. Everything here, with a few exceptions, worked when it came off my car, or the donor cars. Parts located in Brisbane. Pick up or post at buyers expense. I am open to offers, especially on multiple items.
40,000klm Motor (stored for the approx 15 years. $1300
Steering rack $150
Rear diff $150 {40000klm}
oem front exles with good cvs..though boots are split $300 for the pair
Driveshaft with good centre bearing $150
1 new set of cam cover gaskets $30
Door handles with good springs $30
oem speakers 1 front door, 2 rear $30
oem steering wheel $50
various interior trim parts $25
various airbag wiring harnesses $15
various control arms $25 each
upper front control arm bushings x4 (new) $25
ac compressor $75
ps pump Sold
abs pump and module $150
cam lock tool and crank lock pin $100
cam chain tensioner compression tool $25
fan control module $50
Genuine Vag Com cable $150 Sold
egt sensors ×2 $50 for both
O2 sensors ×2 50 for both
Hazard switch $25
Cup holder, working Sold
Climate control module
Auto dimming mirror $50
oil sensor$25
map sensor $25
icm $25
OEM grill $30
various coolant hoses
various turbo and intercooler lines
intake manifold Sold
throttle body Sold
crank angle sensor $30
drivers seatbelt $20
bee sting antenna $15
oem.spider hose and working pancake valve $125
coilpacks x 5 $20 each
coolant after run pumps x3 $20 each
various bolts and other fasteners
vw/audi wheel bolts
Steering rack $150
ac compressor $75
ps pump Sold
Hazard switch $25
oil sensor$25
map sensor $25
icm $25
OEM grill $30
throttle body Sold
vw/audi wheel bolts
