jackal
Changing paddles while initially seeming hard is quite easy.
Here's how it's done
Use a flat bladed screwdriver to prise out plastic tab on either sidewheel. At this stage the ignition will need to be on to turn wheel.
Use a T20 Torx driver to undo bolt under each tab. WHEN FINISHED TURN OFF IGNITION
MAKE SURE IGNITION IS OFF
Remove centre boss (containing airbag) from wheel- pulls straight off. No need to unplug.
Then carefully prise one piece aluminium trim off the three spokes and circumference of centre of wheel.
T20 Torx bolt that secures centre boss can be seen here.
Undo black T15 Torx screw.
Locate red/grey/yellow cable and unclip.
Poke cable through wheel spoke and paddle comes straight off.
