Drying your car with a Metrovac Air Force Car Blower
CarCareProducts
Metrovac Blowers are now available at Car Care Products.
MetroVac Air Force Master Blaster 8HP, the 4HP Vac'n'Blow and soon the 1.5HP Sidekick Blower.
MetroVac’s Air Force Master Blaster dries cars more quickly and safely than any other method – and is the choice of many professional detailers and car enthusiasts around the world.
The Air Force Master Blaster 8 HP blower will help you eliminate chances of marring, scratching, streaking and water-spotting when drying your cars paintwork. This can be safely used on paint, gel-coat, metals, rims, chrome, plastics, glass and many other surfaces to safely blow away water and dust.
And no more water dripping out of your wing mirrors for hours after you have carefully wiped the car dry – this is ideal for blasting water out of hard to reach areas such as grills, door jambs, wing mirrors, numberplate holders, engine bays, badges, body crevices, and wheels – anywhere water can hide. It is also excellent for drying large panels so you can completely dry your car from top to bottom in minutes
The Master Blaster is the top of the range from the Metrovac series with twin 4hp motors providing a huge combined 8hp of ‘Air-Power’ all backed up with 75 years of trusted USA manufacturing from Metrovac.
The Master Blaster Blower is unlike others as it is far more powerful than say a typical leaf blower, so it will dry much quicker, and it is far safer because it uses filtered warm air, ensuring no debris gets blown onto your cars delicate paintwork.
Specifications:
Twin 4 HP Motors with dual-speed fans
• Twin 4 HP Motors with dual-speed fans – 8 HP total
• Rugged, all-steel construction in a powder-coated finish
• Commercial grade 3 meter hose
• Can be used for Automotive or Marine
• 58,000+ ft air per minute (filtered)
• EZ Foam Filter for quick replacement
• Heavy duty power cord
• Neoprene Blower Nozzle
• 240v Australian Safety Certified
The Metrovac Vac N Blo System is the ultimate detailer’s tool! A commercial grade air blower and vacuum all-in-one, which will dry the outside of your car and vacuum the inside.
The Vac N Blo System will help you eliminate chances of marring, scratching, streaking and water-spotting when drying your cars paintwork. This can be safely used on paint, gel-coat, metals, rims, chrome, plastics, glass and many other surfaces to safely blow away water and dust.
And no more water dripping out of your wing mirrors for hours after you have carefully wiped the car dry – this is ideal for blasting water out of hard to reach areas such as grills, door jambs, wing mirrors, numberplate holders, engine bays, badges, body crevices, and wheels – anywhere water can hide. It is also excellent for drying large panels so you can completely dry your car from top to bottom in minutes.
The Metrovac Vac N Blower is the full system from the Metrovac series with a strong 4hp motor providing good drying ability and a powerful vacuum for excellent cleaning ability – all backed up with 75 years of trusted USA manufacturing from Metrovac.
The Metrovac Vac N Blower is unlike others as it is far more powerful than say a typical leaf blower, so it will dry much quicker, and it is far safer because it uses filtered warm air, ensuring no debris gets blown onto your cars delicate paintwork.
Specifications:
• 4.0 Peak HP Twin Fan Motor
• Rugged, all-steel construction in a powder coated finish
• Lightweight, compact and easy to handle.
• Can be used in the home as a vacuum cleaner, blower/dryer or even mattress inflator.
• Mounted Legs with Wall/Table mounting bracket included
• 2 flexible 1.8m hoses
• 2 × 50cm extension tubes for vacuuming
• 4 Piece Micro detailing attachments
• Shoulder strap
• Blower nozzle
• Dusting Brush for vacuum
• Upholstery nozzle attachment
• Dust Brush.
• Inflator adapter
• Crevice tool
Available now for Pre-Order on Car Care Products
