Just recently the blower fan in my 2008 Q7 has been playing up. Usually it will operate at start up but after a couple of minutes the air stops blowing. It will start blowing again, with cooling air after maybe 10 minutes, but stops again after about 2 minutes. It cycles like this on and off.
At first I thought this might be a temperature sensor, so I replaced that (behind the glove box) but that has made no difference. I did compare the resistance of the new sensor vs old sensor and they were the same, with both showing reducing resistance as the sensor was warmed.
I have noticed that this issue occurs more in hot weather (unfortunately) approx 27° or more. Below about 22° it does operate more consistently.
Has anyone experienced this before, and what was the cause and fix?
Thanks.
Thanks.
