New to Audi Forum
HDV65
Hi all , quite new to all this Audi stuff, I have recently purchased an 2010 Audi a4 2.0l turbo B8 FWD, unfortunately for me I have suffered an oil leak
from what I think is from the timing cover area and a slight ticking noise , just wondering if anyone has useful advice as to what parts brands are good
and what parts I should avoid and any tips that may help with the journey I am about to undertake. Tia.
do a bit of a search on the forum under oil leak..there was a bad batch of engines/piston rings that need to be swapped out to fix rhe problem...might not be your model, but worth checking.
Start off doing an oil change yourself. Give her a degrease. Clean it all off.
I find this is the best way to get familiar with a new motor.
You may find it was over filled with oil, or the oil is just old and has lost its lubricating properties and she's a bit noisy as a result.or they used the wrong oil.
Take some photos for record.
Sent from my CPH2333 using Tapatalk
