ozAudi Panic Button (aka Boss Key)
jnrdavo
Administrator
Staff member
Found this on the net today and thought a few of you may like it.
It will display a 'panic' button at the bottom of every ozAudi page. If you click on it (when you boss walks in the room!), it will take you to a pre-defined web site..
ie, Google, or your company page... and viola, you haven't been spending your entire day on ozAudi!
To activate:
Step1: Go your My Profile settings. You can find them on the HOME ozaudi page, on the top right hand corner, as per below:
Step 2: Select About Me as per below.
Step 3: Turn the setting on by clicking on the pencil/pen next to the Panic Button -On/Off Switch and select On. (highlighted above in red circle)
Step 4: Click on the pencil/pen next to the Panic Button - URL Jump and type in the url that you want to jump to. Make sure you start with HTTP://, or it won't work properly (ie, http://www.mycompany.com)
That's it... Once you reload your page, you should see the panic button at the bottom right hand side as per screen shot below :)
The actual panic button could be a bit more subtle...
My about me tab when clicked doesn't have anything under occupation. i.e. not mention of a panic button. What am I doing wrong?
Same for me.
/ found it
I had to go to Settings, Edit Profile, add in Panic Button redirection address and then the option for on/off appeared :)
I had to go into setting to turn it on, it wasn't under my profile.
Also it doesn't work for me it tries to go to http://www.ozaudi.com/forums/www."myworkwebsitehere".com.au
Same for me.
/ found it
Thanks Ozchris I had to do the same,now it works. Is there a way to have a button to return to the page you were on( apart from the back button)?
It doesn't show up in the my profile screen. I fixed it though, I had to put in the http:// and now it works. Thanks.
Hi guys,
I turned on the panic button option, but I cant see it at the bottom right corner of the screen. Is it because I'm using Google Chrome?
Thank you.
